Hello
The problem is that the motor will not always run well at WOT If you pump the primer bulb then it runs normal again
I have tried with 2 fuel tanks Changed fuel lines inside the cover also bought a used fuel pump from a breaker.
Seem to run for a longer time now without problems It can run WOT 10-15 minutes before the problem starts.
The motor is easy to start and runs fine but not on wot.
Any info would be helpful.
Svein
Svein
