I did some re-wiring of my boat over the winter, and moved the battery away from the transom into a cabinet. Also installed a console with nav lights and power outlets for a sounder, gps etc. I want to put a fuse right at the battery terminal to protect the longer run of cables to the motor and console (where there is a fuse block for the accessories). What amp fuse will I need considering the amperege draw of the starter motor on the outboard?
