I had the water pump replaced on my Honda BF200A last summer. Over this winter I lost my mind and ran the motor for 1-2 minutes with the boat on the lift and prop out of the water. I saw a faint sign of smoke from the lower unit area and and alarm went off inside the boat. I immediately shut down the motor, waited for a few minutes, and lowered the motor in the water. I ran the motor for about 5 minutes and it seemed like it was pumping water properly and no more alarm.
Even though the pump seems to be working, do you think I should have the water pump replaced just in case? Are these water pumps somewhat tolerant of running dry for a short period of time?
Thanks.
Thanks.
