Honda BF100 water in engine oil.
I had a problem with the coil and the points, I resolved that problem and was able to start the engine. I ran it for about 15 minutes on and off. Towards the end I could not pull start the engine. I pulled the dip stick and found that the oil looked like a milk shake. After a while I took off the belt off and was able to rotate the flywheel. Where do I start to troubleshoot this problem.
diverpat
Re: Honda BF100 water in engine oil.
It sounds like maybe a head gasket gone bad
