Last week I ordered a 2013 Tohatsu 4 stroke 9.8 outboardonline. Today I filled the motor with Sierra 25-40 outboard oil, put the prop/water inlets in a tub of water, connected the fuel line, opened the vent on the tank, primed it, put it in neutral, pulled out the choke and gave it the maiden pull. all I wanted to do was let it idle for 20 minutes or so before I took it out on a lake this weekend to troll around a bit and continue the break-in period.
Anyway, motor immediately started and water was coming out freely from the port. It started to smoke a bit, light grey, but I didn't think much of it. It was idling rough, then it settled down then you could tell it was not a healthy idle. At that time I noticed some oil in the water. It died just as I was going to kill it. I took photos of the leak. It's leaking to the left of the lower unit oil fill plug. I should note the upper oil plug on the lower unit was torqued so tight I could not remove it to check the level. All documentation says it is pre-filled at the factory and since the plug was torqued so tight (I tried to remove it for several minutes 2 or 3 different times) I assumed it was filled and re-tightened at the factory.
I put the prop back in water and tried to turn the motor over again. It will not start right now.
I am new to outboards and it's possible that is is an operator error somehow, but I do not see how. Any insight or advice? Worst part is the closest warranty dealer is in Phoenix and I live in Tucson.
