Hi I just bought an old (1985) honda b100. It old beat up ,but appears to run good and pump water good. The oil pressure light is not lite, so I have only run it at idle for a minute. i need to check the oil system for pressure but before i go look for a test gauge. i have pulled the light out(undid the connectors and removed from case). How do you test this light? Can I use a multi meter or hook it directly to a battery? Thanks for you help......Robert
