Hi everyone,
I have a 1995 long shaft 5 hp Honda outboard and have been having problems over the past few months. First, my engine would run but would sputter out after a few minutes of running like it was running out of gas. I could pump the primer ball to keep the motor running but nonetheless inconvenient. I thought that what I would need to do is to replace the connector. I was able to track down one of the old-style connectors with 2 round ports and was certain that would fix it. Nope.
Now what I get is a little different - the new connector sprays out gasoline when I pump the primer ball from right where the engine meets the fuel connector. That made me think that I needed to change out the engine side where the connector fits on but same exact result - spraying gas.
I'm starting to think that the problem might be on my fuel line between the gas tank and the connector to hook on to the motor. Has anyone ever seen anything like this before? I replaced the fuel line last year with a brand new line but one thing to note, the new line is larger. It is a 3/8" line. I am not sure what the old line was but I'm guessing 5/16" or 1/4". What size line should I be using?
Thanks in advance for your help. It is coming time to take the boat out of the water and now I'm having trouble starting the motor!!!!
I have attached a couple photos for you to look at the connection between fuel line and motor.
