nissan 2 stroke tach
twowheelonly
i have a 1989 ns40c two stroke with remote control. i would like to know how to wire it to a mercury 40 hp two stroke tach of the same year. i have a pontoon barge with all the mercury gauges and would like to wire up the tach. is it possible and if so how would i do it. ? i bought the tohatsu/nissan manual but it does not have any wiring diagrams . thanks in advance
pvanv
Re: nissan 2 stroke tach
The Factory service manual has wiring diagrams. What manual are you using?
twowheelonly
im using the tohatsu outboards 1&2 cylynder models service manual.p/n 003-21035-1 . it does not have wiring diagrams in it.
pvanv
Incorrect.
That manual has diagrams on pps. 7-7, 7-8, 7-25, 7-26, 7-27, 7-28, 7-29, 7-30, 7-32, 7-33, 7-36, 7-38, 7-41, 7-43, 7-45, 7-46, 7-48, 7-50, 7-52, 7-53, 7-62, 7-63, 7-65, 7-66, 7-68, 7-69, 7-70, 7-71, 7-72, 7-74... and these are in addition to the comprehensive diagram in the owner's manual.
twowheelonly
Incorrect.
im looking for a set of functioal diagrams not component level diagrams. im trying to wire my tach and need to know where to find the sence wire. looked at the owners manuals you described and coul not locate the wiring diagrams. thanks.
pvanv
The complete wiring diagrams for the 40C are on pages 45-47 (the end) of the owner's manual at http://www.tohatsu.com/tech_info/own_man_pdfs/Toh40C.pdf
Apparently the newer Japanese manuals don't retain the wiring diagrams.
BTW, the tach connects to the white and yellow wires.
TOHATSU GURU
And it is very unlikely that the tach will work on that engine. 99 times out of a hundred the engine pulse is too much for a tach of that era.
twowheelonly
i want to thank both of you for being so kind in answering my questions as i am new to the boating world. the service manual is very incomplete . thanks for your help . very timely!!!!!!!!
