fountainboater
- May 2, 2003
- 11
I have a 2003 Honda 225 that I just purchased on a Premier Pontoon boat. The engine only has 50 hours on it. When I first put it in the water it felt like it was running on four cylinders, then after it ran a few minutes it kicked in the other 2 cylinders and ran good. It would run about 5700 RPM at WOT. After being out of the water for about a week I put it back on and now it runs rough and seems to be running on four cylinders again. I can only get 4000 RPM now at full throttle. I checked for water in the fuel and there is none. I am thinking it is either bad coils or bad injectors causing the problem. Anyone have any suggestions. I hve no experience with a Honda four stroke.
