12ftLivingston
- May 31, 2012
- 7
Hi Everyone,
Purchased my 12 foot Livingston and it came with a 2004 25hp Tohatsu. From the beginning it would miss and stumble as if it had bad gas. Turns out it did, the tank was cracked in a couple of places! Replaced tank, fittings, fuel lines, primer bulb, removed and cleaned carburetor, replaced fuel pump. I've been lurking on here and have followed the bump to 30hp and have performed that.
My motor still has the issue of intermittently not wanting to get on plane when the boat is fully loaded with gear and people. With just me, it has no problems. I purchased the Seloc manual for the motor which is good, but not great.
I tested my coil and it failed the tests. My local Dealer is the worst for customer service, so I'm hoping I can send some business to another member. Anyone have any other input? I'm fairly mechanically inclined but I don't do it for a living.
Thanks!
Thanks!
