Aluminium 21ft Have just replaced the head after crack in head. Also replaced seal in gearbox & water pump. All runs well, Have checked that balancers are in correct position. The prop hasn't changed since last in the water. but now apart from the fact that it runs well & compression is 190psi + in each cylinder I have a vibration. don't know where from.
