maineiac5586
- Feb 14, 2009
- 640
Hi, I have a 90's nissan ns8 8 hp longshaft. It gets water in the lower unit. I replaced the washers on the fill and drain plugs. When i had the drain plug out I pressed my air compressor nozzle against the hole and pressurized the lower unit and did not find any seepage. anyone have any ideas where to start? I removed the prop but don't know how involved it is to replace these seals. please help, thanks
I am also confused how water is getting in but I don't see any external gear oil leaks? If water can get in why is the gear oil not coming out from the source of where the water is getting in? Hope that made sense.
