msaunoras
- May 30, 2012
- 46
Alright, new issue I've run across. The engine starts and runs fine (and now it shuts off good too), yesterday I happened to notice a decent sized sheen on the water trailing behind me. Pull the engine cover off and the whole right side is soaked in oil. Check the oil level, it's good but it smells a lot like fuel. The oil only has a 5-6 hours on it. I happened to be in the area of my dealer so I stopped in. He pointed out the oil coming out of the intake(and on the inside of the engine cover) but didn't give me a direct reason of what could cause this.
Backstory is I put synthetic in it. I read both ways on here, some say don't use it others say it doesn't matter. I'll say for sure the synthetic made the problem ten times worse. I've always run merc (quicksilver) semi-syn and it's never leaked bad, I never actually paid attention to where it was coming from. So I drained the synthetic put the old brand oil back in and it's still blowing out.... not nearly as bad though, not enough to drip into the water.
My question is, what the heck is causing this? My oil isnt growing like you'd think it would if fuel was leaking into the crankcase, I check the level all the time and it's not an overfull condition. I don't idle the engine excessively or troll with it. It's pretty much part-wot throttle all the time.
Thanks
-Matt
Thanks
-Matt
