hi my first post here hoping to get help.
the foot is off, the prop shaft is off, water impeller kit is off too. pinion gear is off too, cant get the vertical shift off.
it slides up and down and rotates, just cant get it out past the bearing. wacked on it lots to the point the little bearing shafts busted out of the outer bearing ring. ball bearings are still intact.
any ideas how to get that shaft off.
thanks
thanks
