55evinrude
- Apr 11, 2011
- 252
Hello everyone! after making the choice to go with a new (2011) last years model over a used motor as it was only a bit more $$$. I have decided to make it a 30hp buy removing the restrictor plate. question is some people say it comes set with 25 degree timing some say it doesn't.
how do i check to see if it is already set?? do i just look into the carb to see if the butterfly is all the way open? also briefly when the dealer was running the motor i was looking at it and i seen there where little marks under the flywheel do those have to do with telling what the timing is set to?? you guys let me know how to tell and i will check my motor to see if it is 25 degree timing. thanks!!
Nathan
Nathan
