I recently bought a boat that has a Tohatsu 18hp, 4 stroke motor on it. Model MFS18B2EPL. I am having a issue with it periodically running rough. I have traced this down to the fact that it appears to not be getting enough fuel.
Prior to starting the engine, I pump the ball and the fuel filter is 1/2 to 3/4 full. As the engine runs the fuel filter slowly empties down to almost nothing. Periodically a burst of gas comes into it. It runs fine when idling, since it is not using a lot of gas. However, if I increase the rpm, it will eventually be starved of fuel and start to sputter. Squeezing the ball at that point fills the filter and the engine runs fine again. I have examined and replaced the fuel line from the gas tank to the motor and all seems clear and sound. I have also replaced the fuel filter and verified that the tank is vented properly.
I am wondering if the fuel pump might be bad. If I manually pump it, it seems to be putting out sufficient gas, however it seems to be unable to draw enough gas from the tank. Another possibility is a check valve issue. This is not the original motor on this Bass Tracker. There is a check valve in the fitting just out side of the gas tank. When I inspected the line the check valve was free and seemed to be working properly. However I am wondering if this motor's fuel pump just doesn't have enough draw to open the check valve.
Any help you can provide is appreciated.
Thanks, Bill
Thanks, Bill
