Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
mercury tohatsu 30hp two stroke hard to start when cold
  • mercury tohatsu 30hp two stroke hard to start when cold
    Hi guys
    i have a 2006 mercury/tohatsu 30hp two stroke. i have a problem when starting from cold, air tempertures rarely lower than 10c , so not cold climate. its fine when it has been started once and will start straight away, and performs really well under all loads . but when cold it is a pig to start and may require 4 or 5 good long turns of the starter before she starts. i follow the owners manual starting procedure so not sure. would appreciate any help
    thanks
    kinger
    Re: mercury tohatsu 30hp two stroke hard to start when cold
    Welcome to the Forums...
    These 25/30 models are sometimes sensible to temperature, check this temp info. Check with yours and match any of the 3 starting procedures...
    Happy Boating
    Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
    • #3
      Happy Boating
      HI those are the instructions for the tiller model. mine has remote controls, but i have the owners manual and have followed those instructions to the letter.but still no joy
      • #4
        Is the air butterfly solenoid working properly when pushing/releasing key button, or the plunger gets stuck inside solenoid ? Is your battery well charged ?
        Happy Boating
        • #5
          hi thanks sea rider will try that, its got to be to do with the choke as it runs and starts pefectly , after initial starting. when the wind stops howling and the rain stops pouring down will have a look
          regards
          kinger2111
          • #6
            this may sound crazy to some but have ben at the ramp watching boaters crank their motor . they would push and releas the chock several times and then try to start the motor insted of holding it in while turning the key.not being crazy just don`t understand .be sure the butterflys are closed compleatley .
            • #7
              Will entirely agree on that, people turns sometimes cracy cranking engines; Prime engine, move throttle a bit forward, push key in and without releasing proceed to turn key to start. Repeat if needed. If engine cools down fast after boating for some time, move throttle a bit forward and start, if doesn't start at first or second intent will need to perform complete cold start sequence again. Both works fine for me.
              Happy Boating
              • #8
                The design is not "cold natured" in any way shape or form so the problem is due to some specific cause. It could be as simple as tiny air leak in a fuel coupler or be complex with more than one thing being wrong at the same time. I would suggest taking it into a dealer and leting them determine the problem and correct it. Or, pick up a service manual, pick one of the engine's three main systems and start troubleshooting...Chances are you have a fuel system issue so that's where most mechanics would focus their attention.
                Elvin
                My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
                The 3 Rules:
                1) Look in your service manual first...Then ask me if it is correct.
                2) Understand that your desire to repair your engine does not mean that you have the ability to do so.
                3) If you are confused, take your engine into a dealer..Then let them be confused...At least, in theory, they sent someone to outboard 101.
                • #9
                  Hi guys
                  have found the problem it was the choke solenoid sticking so not closing the butterfly. pulled the manual choke and it started first time. so have freed up the solenoid and its working prfectly now.
                  thanks guys for your help
                  rgards
                  kinger2111
                  • #10
                    Check plunger clean/dirt condition. In most cases plunger sticks inside solenoid due to solenoid's bracket misalignment at base, check/correct misalignment, if ok, there are 2 small screws that holds solenoid to upper base, will need to play/adjust them properly untill plunger works freely back and forth with finger.
                    Happy Boating
