Dip Fortuna
- Apr 11, 2012
- 5
Well, I decided to put a hydrofoil on my brand new Nissan (4stroke,15hp). To drill the holes, I had to remove the prop. I didn't notice the prop washer fall in to the grass. So, when I tested the motor in a local lake, the prop got all chewed up from hitting the bolt heads on the housing. Long story short, I bought a new prop and housing assembly, which includes one set of bearings and one o-ring. My question: How should I proceed? I assume I should drain the gear oil first. Do I need to apply any sealer on anything? I haven't worked on anything newer than 1972 before and I can't afford to make any more mistakes with this one. Any pointers would be greatly appreciated! Thanks!
