Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
Announcement
Collapse
Help Tip: If you have a question that has not been answered to your satisfaction in the archives, it is always best to start a new thread of your own. By starting your own thread, you will receive the maximum number of views by forum members.
Below are some additional forum policies in hopes of all iboats members will follow, Thank you.
1. Please do not reply to old topics or hijack existing topics. Old topics of a technical nature are like a library book, Please do not write in them.
2. Old topics should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
4. If you have a question for the original poster (OP) and the topic is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old topic.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís topic. And those answers will be specific to your particular issue.
6. Please do not post to topics that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any topic that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old topic.
7. Posting at the end of any topic is considered to be hijacking the original posters topic which in turn subjects the topic to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive topic asking you not to reply to old topics. The Red banner will read: Please note this topic has been inactive for 90 days. For the best results, please start a new topic.
Thank you all in advance for doing your part in helping iboats run a smooth ship.
Additional forum rules linked below.
http://forums.iboats.com/forum-rules-guidelines-405/
See more
See less
25hp Nissan prop doesn't turn and water pump will not pump
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • 25hp Nissan prop doesn't turn and water pump will not pump
    I've meesed with outboards a while this is the first I've seen where both prop and water pump don't work. I assume it is drive shaft related. Just quit working will motoring no other symptoms. Motor still idles fine.
  • #2
    Re: 25hp Nissan prop doesn't turn and water pump will not pump
    What is your model? If you drop the LU, is the driveshaft in one piece?
    Paul
    Buffalo NY USA
    Comment
    • #3
      The two things are independent of each other. So, unless you have a broken drive shaft, the problems are not related.
      Elvin
      My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
      The 3 Rules:
      1) Look in your service manual first...Then ask me if it is correct.
      2) Understand that your desire to repair your engine does not mean that you have the ability to do so.
      3) If you are confused, take your engine into a dealer..Then let them be confused...At least, in theory, they sent someone to outboard 101.
      Comment
      • #4
        NS25C3 2001 I'm not sure, I did notice there didn't seem to be any splines or a key just a smooth shaft.....
        Comment
        • #5
          Sign up today
          Are you saying the top end of the driveshaft doesn't have splines? If so, it is probably snapped off, with the splined portion stuck in the crankshaft.
          Paul
          Buffalo NY USA
          Comment
          Back to Top
          Working...
          X
