I have read a ton of these forums and finally just decided to detail what I have done so far and see if anybody can help me pin point the problem.
I have replaced the water pump uper housing after finding a crack in the old one.
Replaced Impeller, guide plate and gaskets, rubber seal to the lower water pipe and the key.
When I hook up a hose to flush I can see water come out the tell tale. When I have the lower unit off I can see water coming out of the water pipe.
Any help on identifying the problem will super appreciated.
Thanks,
Thanks,
