Sorry, in advance, if this is a silly question.:facepalm:
I just wanted to confirm that when I'm under power, the tilt setting for the motor (manual tilt) should be in the "Run" position, and if I run into any submerged objects, the motor will respond by swinging up following impact. There are only two settings, "Run" and "Tilt", and I just want to make sure I'm running in the correct manner.
I'm new at this and don't want to lose the lower part of the leg if I hit a stump.
Thanks,
Terry
Thanks,
Terry
