Re: Nissan 5hp power problem
Thanks for your help. It is an NS5B. The old sparkplug looked quite clean two days ago. I will have to check the new one. The float is correct if I understand how it should be done, which is that it should be parallel to the bowl edge when the carburetor is turned upside down. (Please correct me if I am wrong.) I run standard two-cycle oil 50-1, right now Mercury brand. Cooling system is peeing nicely. The lack of power occurs even immediately on start-up, when the engine would be its coolest. As for the carb cleaning, I disassembled it, including the jets, sprayed all channels several times with carb cleaner, using the little straw that comes with the can. Then I blasted it with compressed air. It certainly remains a strong possibility possibility that there may be a little piece of dirt in there somewhere that I can't see. I don't have the immediate ability to actually measure the compression right now or the ignition components, so I think I will tackle the carburetor again. I was wondering whether you think this might be a fuel pump issue.
Re the bottom end, it was some sort of bearing. I would have to check my records, which are buried right now, but that is probably not necessary to solve the immediate problem. The work was done in Central America so most of the conversation about it occurred in halting Spanish.
Again, thanks very much for your help.
