romanfishing
- Jul 17, 2010
- 2
Hi,
I have replaced the impeller but it is still not circulating water. My engine is setting alarm off after running for two minutes. It is basically brand new engine but Honda is refusing to fix it under the warranty assuming it as two year service with minimum charge $300. I am thinking maybe it is a faulty thermostat after running in salt water that should be cleaned. However, my manual does not show where the thermostat is located.
Any help will be appreciated.
Thank you.
Thank you.
