Ian Kicker
- Oct 31, 2011
- 3
Changing the gearcase oil for on my 2003 motor.
After allowing the gearcase oil to drain for 24 hours I tried to refill the gearcase accoring to the instructions - i.e., forcing the oil in the lower hole by squeezing the tube of oil. But the oil would not go in. On checking the upper plug opening I observed a lot of white flaky material. I removed as much as I could with a small wire and, eventually, I tried my drill with a small bit. I was able to blow some stuff out but the hole is still plugged. I tried some WD40, but it just sat there and did not penetrate. The only way I could get oil into the gearcase was by turning the motor upside down and dripping it in the lower hole. Incidentally, nothing came out the upper hole even though both plugs were out and, since the motor was upside down, it was the one closer to the ground.
Questions:
1) What is the junk inside the upper plug hole and how do I get it out? How do I know when its all out?
2) What does it mean that there's junk in there? The old oil was not milky, so I don't think this is salt.
3) If this is the result of some sort of galvanic corrosion process, how do I stop it (the anode looked not too bad - is all clean and shiny now)?
4) Could whatever have caused the blockage have done some more serious damage to my gear box?
5) Is it OK to use the motor now? -The gearcase is full (albeit by flipping the motor upside down and dripping the oil in the lower hole) and the two plugs are secure. Also, is it really full since it is not possible to do a oil level reading at the top oil plug?
6) Could my digging around in the upper plug hole and the WD40 have made the situation worse?
Questions:
