sdanville
- Mar 14, 2007
- 18
So I rent out my 2002 honda BF5.
I knew one day it would get messed up. The killer is the last renter said they did not do this so I have no
knowledge of what happened.
I found a wire going from under the hood to the upper part of what I will call the vertical throttle shaft - it was connected to a piece of metal that had a pivit point..and was used to pull the part manually for some reason.
There is a spring towards the top of this shaft that has a hooked end that was disconnected. the spring does not seem broken..but i have not examined it much. I have lots of photos. not sure if they had the wire there so the recoil would work, or if it would shift of what. Very frustrating they claim no knowledge. That means a thief in the night stole my boat, cobbled the motor and returned it.
I will try and post a photo as my description must sound ignorant.
steve
steve
