grimalkin9999
- Sep 6, 2011
- 1
I found the manual release valve has been oxidized and was leaking ATF. I ourchased a new one but cannot get the 2 trim cylinders and longer lift cylinder to function. I tried many cycles up and down with the longer lift actuator disconnected. I've filled the reservoir with all 3 actuators extended fully. Any ideas??? The fluid appears to be pink and filled with micro bubbles.
