Re: How to winterize Honda vtec 90
Yes yes yes.. To all. The last post was very accurate too with the things needed. I'm from Ohio and now I live in Washington so winterizing is kinda in my blood...
Anyways, with any Vtec you HAVE TO CHANGE THE OIL! Vtec runs off of oil pressure and poor oil change maintenance is usually tied to Any Vtec failure. Changing the grerlube is essential too because if there is a leak and water is in there it will freeze and crack the casing. Plus winter is a great time to fix that stuff so you are not working on it when you want to play in the water next year.
Fogging oil is easy and keeps the cylinders lubricated for the layup. I usually did this step last after everything is done. (on an efi engine) All you do is shut the motor off, let it cool a little, remove the plugs, and spray about 1to 2 seconds worth of fog oil in each cylinder. Then, either spin the flywheel 2 revolutions by hand, or bump the starter (with the lanyard DISCONNECTED) to distribute the oil. Put the plugs back in, tilt the motor, put tape over the hub of the prop (to keep water from getting in the hub and freezing), disconnect the battery... And light a fire because it's probably cold outside. Pour some Baileys in your coffee and watch football.
