Rick Russell
- Aug 6, 2011
- 32
Trying to reinstall the driveshaft after replacing the gasket to my lower pump case on my Nissan 4 stroke 9.8A and did not do a very good job of remebering what the order of parts were on the shaft (note to self, take pictures next time). Here are the items I am concerned about:
1. There was a very flat ring, which could be the gap liner when you look at the parts manual.
2. A small sleeve about 3/4 inch long. I hope this is not the needle bearing! Which, I don't think it is, because it took no effort to take out ( the SELOC manual made it seem like it was a big deal to remove this with all sorts of special tools). It just slide off with the drive shaft, but I can't think of what else it could be.
3. Small washer.
The parts manual is in conflict with the SELOC manual, which is why I am here. The SELOC manual also has some holes, which is fair or the manuafacturer put some extra parts in my outboard that would not normally go in there.
The order that I placed the parts into the driveshaft assembly is
1. Small sleeve
2. Large sleeve (about 6 inches long)
3. Small washer
4. The ball bearing (was still attached to the shaft, I never removed this)
5. Gap liner
6. oil seal (never actually removed this from the lower pump case )
7. Pump case.
Any comments?
I've seen some great posts on this site, so I'm hoping to benefit from the same knowledge.
Thanks folks!
3. Small washer.
1. Small sleeve
3. Small washer
5. Gap liner
7. Pump case.
Any comments?
Thanks folks!
