PhatFireMan
- Aug 3, 2011
- 3
Need advice,
I just bought a used boat, has a 2006 Honda BF 225hp outboard on it, 250 hours, runs great. I was detailing the boat today and noticed that one of the three bolts, on the port side of the outboard, that mount the lower unit to the mid-section, is slightly backed-off, about two threads worth.
The only reason I caught this is because as I swept my hand over it, the washer made a little rattle noise. The bolt is not "loose", I cannot turn it with my fingers, but it is not fully seated. I cannot see any gear oil seeping out from the lower unit seam at this time.
Before I put a socket on it and cinch it up, I wanted to be sure that there is not some sort of torque pattern on the lower unit that I am messing with, or sealant inside the bolt hole of some kind, etc.
Anybody know if I can just go ahead and turn it? If so, anybody know the torque setting by chance?
Any ideas on why this occurred and what might be going on as a result?
I have not had the chance to release a drop of lower unit oil yet to check it for milky-ness. Will do that tomorrow.
Thanks,
Kris
Thanks,
Kris
