JudgeSmails
- Jun 20, 2011
- 3
Just repowered with a 1997 BF90a I recently purchased. Before purchase did the usual compression check, inspected quality of the oil and lower unit grease. Ran in a tub and sounded good. Yesterday was the maiden voyage after putting it on my boat. Ran it gingerly for about a half hour and it seemed fine and sounded good. Did some WOT testing and all sounded good. Stopped the motor and drifted for about 20 minutes to have some lunch. I started it up and it stalled when I threw it in gear for a hole shot test. Started right back up and I did a more gradual acceleration which seemed fine. Ran around for a little while and everthing seemed normal until I tried to slow down for a cruiser wake and the throttle stayed stuck open. I killed the ignition and avoided swampage, but so much for feeling good about the new motor.
I took the linkage cable off thinking it slipped adjustment or something, but even with the cable off, the carb throttle would not snap back to idle. Nothing external seemed to be causing a blockage. I hooked the linkage back up and hoped for the best by starting it back up and immediatly throwing it in gear to get myself back to shore. Once I was within trolling motor range I put it back in neutral and this time the engine was able to rev down to idle. However, idle seemed a bit rough compared to the beginning of the day, and had a much more pronounced 'engine shake'. There is a pretty long no wake zone back to the dock, and after about 10 minutes of rough low rpm trolling there was a distinct misfire sound in quick sucession then the idle seemed to sound a little more normal. I landed with no trouble.
The air silencer cover over the carb intakes has a crack at the top that the previous owner tried to apoxy. There is a dime sized chip missing, but that is not new. I assumed it was simply missing and a cosmetic issue but did not pose a problem. I hadn't thought of it, but I suppose it could have been floating around on the inside of the air silencer housing. Is there any air filter or anything on the inside that would prevent something like that from getting sucked into the carbs? Any other reason why the throttle at the carb would stay stuck open like that? I've always had an older two stroke in the past and done carb rebuilds, but I'm reading that it's a totally different animal with the Honda 4 strokes. Should I do another (nearer shore) sea trial or is it straight to the mechanic for me? Any advice or cyber diag is appreciated.
