Grant Brown
- Mar 13, 2004
- 390
I have a 1990 or so Honda 10hp Blue/White w yellow prop. For some strange reason it won't idle. Starts fine and runs at higher RPM, but as soon as I let off it dies. It ran good up until last summer and then started acting up every second or third trip out.
I cleaned the carb 4 times ( even had a buddy who works for the city small engine repair shop put it all in the ultrasonic tank), I tried pumping the primer bulb, replaced primer, hose and the fittings w new, checked and cleaned the fuel pump 2x, checked for air leaks at base of carb with ether, replaced the plugs and even convinced another buddy with a good running 8 hp to try his carb and fuel pump on mine just to eliminate them. Nothing helped it - still won't idle.
This has been a great motor but I have almost had enough. I am looking for a replacement, but I would rather spend the money elsewhere right now.
Grant
White Rock, BC
Grant
White Rock, BC
