makassiouk
- Aug 2, 2010
- 12
I stuck the multimeter set up for voltage into the accessory output on my motor and found no uncle Electricity living there. Went up the cirquit with the same instrument and found nothing further up either (passed fuse and a couple of connectors).
There's a device (regulator) with a biggish heat sink on it - from that one 12V should be output, no? I have no idea how to test further...
If I rev the motor up, I see voltage climbing from 0.00 to 0.06-0.07. Is there an explanation for this?
1. Is the measurement device wrong for this task (something to do with impulse power sources comes to mind)
2. Does being or not being in gear matter?
3. What do I do next?
