I have a Honda BF8, the "pee hole" is only dribbling, however the impeller is good.
I know that the impeller is good because if I pull the hose directly from the the thermostat connection, I get a good, forceful water flow.
I've only idled the motor, as I don't want to take it out and destroy it, but even after idling for 10 minutes, the block doesn't seem to get warm enough to open the thermostat.
The intake/thermostat cover is stuck on pretty well, so I can't just pull the thermostat and stick it in a pot of boiling water.
So my questions are;
Is this normal? Or should I always have a solid flow of water ?
How can I safely/easily remove the thermostat/intake cover without destroying it?
Thanks!
Thanks!
