Just changed oil in my 18 hp.Replaced filter w/fram ph6607.When I started motor,oil light is on and will not go out.Have had occasion on startup when light would stay on but go out on restart.Now light is on all the time.Could changing oil cause this?I have checked ground from sending unit.Also I just installed remote control and went to lake&everything was fine.Problem just arose after oil change.NEED HELP
