I'm rigging a "Get a Customer Home Motor" for a Seaswirl 2150 O/B Walkaround (4k loaded)and want to get him setup well, should the need arise for its use (ie: O/B croaks)
It is a four stroke 2007 9.8HP. It will NOT be used for trolling.
I believe the choices are a 5" and a 7" and am I correct that the Tohatsu and Solas are identical, although the iBoats picture appears otherwise.
It'll be used in open water in the Boston area ocean, so there could be winds and waves.
I know a few of you guys have been around the block with this, so if you have a moment, please weigh in. Thanks!
