dedwards04
- Feb 7, 2011
- 2
ok guys i have a 98 3 cylinder 50hp tohatsu. been messing with it for about a week now and im running out of ideas. its kind of hard to get started at first and when it starts it will idle a little ruff and soon after die. i went through the carbs cleaned them, put new plugs in, new fuel pump diaphram kit, and changed out the primer bulb becasue the one i had wouldnt get hard. i bought an attwood bulb and it wouldnt get hard either so i went and bought a sea sense bulb and it built up pressure and got hard only once. well it seemed to be runnin alright on the hose so i take it out to try it in the water, it started up fine, idled ok, when i put it in reverse and gave it gas it died. did this several times. after i floated out a bit i decided to try farward out and it was the same thing. just as i was going to idle back to the dock i tried one more time and it acted like it wanted to get up and run so i gased it more and sure enough it took off. ran great. went up and down the river stopping and turning around several times. i thought it was good to go now. after killing it to get truck in the ramp i started it back and same thing. dies when i put it in gear and give it gas. what does this sound like. my airmixture screw i noticed is 3 1/2 turns out. could this be my problem? also the bulb never really gets hard but i always have gas in the fuel filter and its not leaking any where when im pumping it. any help will be greatly appreciated
