Old faithful finally gave me some trouble. Put boat in water after extended period. Started no problem and ran great but bottom carb was leaking fuel. Tapped a few times with screw driver handle did the trick. Motor starts and runs great to 3000 rpm. Thought it might be a carb problem but noticed something funny with remote throttle. When the engine is running and in gear forward/reverse the throttle linkage will not run to the stop (max power). When motor shut down and throttle pushed to max it goes all the way? Could this be a remote throttle issue?
