the 15 hp nissan on my duck boat was recently sucked some debris up into the water tube causing an overheat. after removing the cylinder head i cleaned the water jackets, checked the thermostat...etc...I also decided to replace the impeller since its been about two years, however, the lower unit would not drop down. shift linkage is disconnected and all bolts are removed. i thought that the drive shaft may have been frozen into the powerhead, so i pulled the powerhead...which came easily off the shaft. I've tried tapping on the lower unit with a deadblow mallet and with a 3lb hammer and block of wood but it will not budge at all. am i safe to try removing it with some heat or is there another better option?
