Is the mixture fixed at higher rpm and only ( high speed jet )
And adjustable for idle only? The plugs looked pretty wet after running in trash can. could this mean that i should lean out the idle. the plugs after years of use had some black crust on them and tend to get wet with oil and or gas.
I baught it used and am just trying to dial it in.
Thanks for any advise. I will be using it on a sail boat ( it is a long shaft)
Oh yeah how do i adjust the idle mix if i should?
Thanks
Thanks
