I took my boat for the maiden voyage and started having throttle issues. We went WOT from the landing to the mouth of the bay so about 15 mins. All of a sudden the RPMs sky rocketed and I throttled down. Then while trying to idle it died. I figured it was ventilation. Sound correct?
I then had a little trouble getting it started again. I finally did and we were under way under WOT again. Same thing happened.
We turned around to get home but as we went I noticed that I was not able to get all the power out of my engine as before. Originally we were cruising at about 5400 RPM hitting 30 MPH or so. As we went I noticed that we couldn't go over 3400 RPM or the engine would quit. The RPMs would slowly start decreasing RPM without me touching the throttle. by the time we got to the landing again I tried to get WOT but even with my throttle full open I could only get 3200 RPM. I took the cowling off and everything looks tight and good to go other than the drain screw on the carb is leaking. Would that have something to do with my trouble?
I got the boat home and flushed the engine and it will idle and get in gear forward and reverse. Unlike while in the water, where I had to quickly lower the throttle lever on the top of the throttle case and push the throttle forward to get in gear and keep the engine running.
Please help with terminology and my problem. Thank you in advance.
Joe
Joe
