Dino Green
- Sep 20, 2010
- 2
I have a 40hp Tohatsu M40C, 361a, 88929 are the #'s I found on the motor. Seems to idle and start well. Little studder on idle but, at full throtle is seems to go pretty well and then starts to die. I notice that during idle the primer blub is pretty firm yet at full throtle when it starts to die it feels quite a bit softer and almost feels like it has air in the line, if I give the primer bulb a pump or two it picks right back up for a while then will start to die again until the pump is given to the bulb again. Could this be a clogged or dirty fuel pump or is it a possible fuel pickup issue.
Thanks in advance,
Dino
Thanks in advance,
Dino
