Cranked motor, no water cooling, removed thermostat still no water, removed lower unit to check impeller. No ears gone, not brittle, very pliable, fits snugly in sleeve. Water tube clear and fits into pump snuggly. RAN MOTOR WITH EARS, NO PUMPING, PUT IN BARREL AND COMPLETELY SUBMERGED LOWER UNIT, still no water. Drive shaft secured to water pump with key and operating correctly. Need some suggestions. Thanks
