This is a BF8A, approx 1991 to 94 vintage. New to me. Motor wouldn't start first time I tried it, and I had it serviced. Apparently prev owner had not used it in maybe 2 yrs, so carb was gunked up. They cleaned it, put in new plugs.
It has been very hard to start, takes a good 25 or 30 pulls, I'd guess, maybe even more. This is when cold, fully choked. I have pumped the bulb until it is hard. After all this pulling, it fires a bit then maybe 2 pulls later it starts. It has tended to stall at idle, particularly when shifted into gear. I did screw in the idle stop screw slightly, thinking maybe the idle speed was too low - seemed to help the stalling, but I suspect idle speed is a bit fast, making slowest boat speed (throttled all the way down) a bit fast.
I haven't found any posts on hard starting yet. I wonder if there are a few typical causes? Gas (10% ethanol, 87 octane) is fresh (like 1 week old). Engine did run fine at moderate RPMs, for maybe two hours while we were cruising, so fuel seems to be flowing OK at speed.
