davidcampione
- Jul 25, 2010
- 9
After a fishing trip the other day i noticed a large spot of oil below my 2006 6hp outboard.
The oil leaking wasn't dark, or milky, it was a clear fresh motor oil look. It was leaking out of all the screws on the lower unit even the bottom one on the hub near the prop. I thought I rotted a gasket but not the case. I unscrewed the lower unit oil ports and it dripped out a thin milky substance.
I assume I got water into my gear oil. But how? Why is it leaking unexplained from sealed areas? It even was coming out of the circle rubber thing on the shaft (what is that?) Shouldn't the oil that leaked be milky too?
