I have had my motor sitting up for sometime in the shed. I was taking it out today and while I wheeled it around to the boat, it fell off the stand.
I now have a very small gap where the arrow is pointing in the picture. When i hook up the water hose and run the motor it shoots out through this gap and also a little out of the exhaust. The gap is were the bottom cowling(case) meets the extension case. I need to know if this will hurt the motor or if water should be coming out thru there. The motor runs and idles perfect still, just need to know if its safe to run with this. I will try and get pictures up later.
Thank you.
Thank you.
