TECHNOHEAD
- Jun 21, 2010
- 8
I have a 2002 Honda 9.9 which I purchased used last year. It has been a bit touchy starting and restarting, but after replacing plugs it seem better till this year. It starts on first or second pull, but I seem to have to leave the choke out just a little, a bit longer than I would think. Then after running at 3/4 troddle for 5 to 10 minutes I try to return to idle and it stalls. It restarts very hard and I usually pull the choke out initially, which seems to partially flood it, then I push choke in and give it about 3.8 troddle and it fires right up, but does not want to idle for a while unless I pull the choke back out about 1/8 inch. Also I noticed the squeez bulb is soft when this happens, but manual says not to pump it up or you will flodd carb. Is this problem a dirty carb and if so will some kind of fuel additive help or is it possibly a partially plugged crank case vent tube, like someone else had on the site.
