Hi!I was looking for help,and there seems to be some very knowledgable people here.
I have a 1998 Nissan 30hp tiller control on a 14x48 alumicraft.
My issue is that when it is wide open,the power fades,when I back off it picks back up.I may lose 3-5mph.
Since this issue I noticed my top plug wire was slipping out of the boot.I got some electrical tape,and taped it real good.A friend tried to move the plug wires while it was running,and just touching the wire shocked him bad..It shouldn't do that should it?
I have installed a see thru filter,and I have noticed there was air getting into the line.And that the fuel would drain back into the tank.I replaced the fuel tank,and bulb.There is still a small amount of air in the fuel line.The power fade problem isn't quite as bad,and when I pump the bulb it does seem to pick back up.
I also noticed as I turn the handle the carb opens,and I assume the timing changes as well,but just before wide open the carb quits moving,but the timing keeps going.Could it be getting out of time on top end?
Do you think this is a fuel line fitting issue,or fuel pump issue?
With no one but me and my son in the boat it will fly,and doesn't have that problem.It is just noticeable when there is a boat full of people.
Thanks in advance!
Thanks in advance!
