I just purchased a used (circa 1995) 8hp Honda that is in very nice condition, but doesn't run right. The guy said that he has to keep priming the bulb to keep it running and it runs rough when it does run.
I did notice upon inspection that the timing belt is somewhat loose. I will go ahead and replace it but I need to know where the marks are to set the cam gear to the flywheel.
Any pointers and things that I should be aware of??
THANKS IN ADVANCE!
Tronald
THANKS IN ADVANCE!
Tronald
