Jake Windemere
- Oct 26, 2008
- 73
I have a 2008 Honda 20 horse outboard (BF20DKSH). It came with a 9 1/4 x 10 (235 x 254 mm) four blade aluminum propeller.
I put the engine on a 14 foot Zodiac MK II Grand Raid inflatable.
The boat was slow out of the hole so I replaced the 9 1/4 x 10 prop with a Solas 9 1/4 x 9 aluminum prop.
The boat is still a bit of a dog out of the hole. It does okay with a light load but takes a while to get on step with a full load.
I have a Tiny Tach induction tachometer on the engine and I find that the engine tops out at about 4800 RPM and between 15 and 17 mph (load dependent) when running at WOT.
I'd like to tweak the system further but don't know where to invest. Do I put a three blade prop on the engine? Do I switch to stainless? Do I further reduce the pitch? Do I add a Stingray Hydrofoil? Should I try to get the top end (5500 RPM)?
What would you do?
What would you do?
