jonaddis84
- Oct 8, 2009
- 7
I just got a great deal on this '99 18hp with maybe 4hrs from an old Nissan dealer.
Motor runs great, but since its sat for 10 years I decided to replace the impeller to be safe. Turned out it was perfectly fine though so now I have a spare.
While I had the lower unit (LU) off I noticed a BUNCH of nasty watered down oil almost completely blocking off the exhaust port in the LU. There was also some of it in the top side just above the LU. I sprayed some degreaser and washed it out of there.
After re-assembling, I ran it for a few minutes with the muffs to make sure everything was cool. Now after sitting in the shop overnight I noticed some more of that nasty oil has dripped onto my floor.
What causes this?
It cant be LU gear oil, Ive replaced that twice, once right when I got the motor a few days ago, and I drained it before doing the water pump. There was still a full amount of gear oil that drained out of there.
Could it be running too rich or I have too high a oil ratio in my gas and its spitting it all out the exhaust?
Thanks
What causes this?
Thanks
